This thread was closed and archived. Please ask a new question if you need help.
Thunderbird 115.0 64bit - change background colors
  • 2 replies
  • 158 views
  • Last reply by sfhowes
was recently forced to upgrade to winblows 11.. in the previous version of Thunderbird, 102.2 64 bit, I could follow these instructions to background colors in the various panes .
https://support.mozilla.org/en-US/questions/1389364
Now with version 115.0, I am having issues getting it to work.
the CSS file I am using is
  1. threadTree > treechildren {
 font-size: 16pt !important;
 font-family: Times !important;
 background-color: lightgrey !important;
 color: navy !important;
  1. folderTree > treechildren {
} after I follow the instructions, carefully, nothing happens. see screenshot attached...
I have 2 questions:
1 - what am i doing wrong? 2 - In the attached screenshot, how can I get rid of that toolbar in green on the left?
was recently forced to upgrade to winblows 11.. in the previous version of Thunderbird, 102.2 64 bit, I could follow these instructions to background colors in the various panes . https://support.mozilla.org/en-US/questions/1389364 Now with version 115.0, I am having issues getting it to work. the CSS file I am using is #threadTree > treechildren { font-size: 16pt !important; font-family: Times !important; background-color: lightgrey !important; color: navy !important; } #folderTree > treechildren { font-size: 16pt !important; font-family: Times !important; background-color: lightgrey !important; color: navy !important; } after I follow the instructions, carefully, nothing happens. see screenshot attached... I have 2 questions: 1 - what am i doing wrong? 2 - In the attached screenshot, how can I get rid of that toolbar in green on the left?
Attached screenshots
To hide the Spaces toolbar, click the arrow icon in the attached picture.
Try this.
Folder pane:
@namespace html url("http://www.w3.org/1999/xhtml");
#folderPane {
background-color: #87CEFA !important;
Threads pane:
table[is="tree-view-table"]{
background: #87CEFA !important;
To change the font size, use View/Font Size.
To have the font-family applied, 'Allow messages to use other fonts' must be checked in Settings/General/Fonts & Colors, Advanced.
Code supplied by users here.
Help/More Troubleshooting, Profile Folder, Open Folder, close TB, create a new folder named chrome, create a new document in chrome with a text editor, name it userChrome.css (userContent.css), Save as type: All files *.*, copy in the above code, change the numbers and colours as desired. Double-click toolkit.legacyUserProfileCustomizations.stylesheets to true in Settings/General/Config. editor, restart TB.
https://www.userchrome.org/download-userchrome-css.html
Modified by sfhowes
